I have an off-grid orchard which has a well pump running directly off of a 24v PV array. (27-32v when at full power) Parallel to this direct circuit, I have a buck converter to power a Raspberry pi (via GPIO), which has a switching solid-state relay and a camera to watch the pump and its gauge.
When the Pi triggers the SSR, the voltage coming into the buck drops from 27v to 24v on my multimeter (I don't have an oscilloscope, so perhaps its more of a severe drop), and this causes the output voltage to briefly go to zero, causing the Pi to reboot.
While it's entirely possible this is the fault of the cheap 12v/24v to 5v buck I bought on Amazon, I'm wondering if this is expected, and if so, can I do something like add a capacitor, either on the input or output to buffer this, and keep the pi running.
