I would like to control one of these 8-relay boards with my RPI GPIOs.
Please check the below schematic - it shows the parts involved for one of the 8 relays. JD-VCC is connected to the 5 V of the RPI, because the board uses 5 V relays, that's fine.
I'm unsure if I should use 3.3 V or 5 V for VCC (e.g. driving the optocoupler). I found several tutorials in the internet, some of them say 5 V, some 3.3 V.
Since some of the tutorials recommend using 5 V for VCC. I was asking myself if that damages the RPI's GPIO, because as far as I know, they are not 5 V tolerant. However, measuring the voltage on the IN1 using my multimeter results in 3 V. I guess this is due to the optocoupler diode forward voltage and also the forward voltage of the IN3 LED.
I'm not a professional EE, just a tinkerer, and I would just like to have the assumptions mentioned above confirmed. Is it safe to use 5 V for VCC?
