I have 3904 and 3906 transistors, LEDs, and an SPDT switch.
I tried to use the 3904 so that when voltage is applied to the base, it flows from the power source into the LED and then to ground.
I have difficulty to use another transistor so that when 0 V or ground is applied to the base of the transistor, the LED will turn on. How would I do this?
In other words, the SPDT switch will toggle 2 LEDs; one LED will show the on status and the other LED the off status.
The schematic I drew below is working, but I need to add another LED that will switch on if the voltage is 0 V or ground.
