I'm trying to diagnose the significant amount of bus "stuff errors" on my CAN network. Network is new and has not ran without these errors. Topology is as shown below.
18 Devices on CAN bus. 9 on each side, joined at din rail terminals.
Cable on the outside of dotted lines are this twisted pair cable.
Cable on inside of dotted lines to din rail terminals is this shielded twisted pair cable.
Dotted lines represent deutsch connector.
Bus length is roughly 20m - 25m
Bit rate is 500kbits/s
My question relates to the physical layer because I can be fairly sure software is working correctly.
Can any of the following things cause stuff errors on the bus?
- Two different cable types
- Sections of non shielded cable
- A bad high or low connection to a device
Here is a picture of the CAN signals on a scope.
Here is an example of CAN traffic showing errors:
355) 4916.3 Rx 0520 5 A6 0C 64 00 06
356) 4919.6 Rx 0523 8 05 00 00 00 41 00 00 00
357) 4919.8 Rx 0526 6 C0 01 08 00 08 01
358) 4920.3 Rx 0525 6 A8 73 AC 0D D0 02
359) 4920.5 Rx 0525 6 34 73 AC 0D D0 02
360) 4920.7 Rx 0523 8 B4 00 00 00 40 00 00 00
361) 4920.8 Error 0004 4 01 0A 01 00
362) 4920.9 Error 0004 4 01 0A 02 00
363) 4920.9 Error 0004 4 01 0A 03 00
364) 4921.0 Error 0004 4 01 0A 04 00
365) 4921.2 Error 0004 4 01 0A 05 00
366) 4921.2 Error 0004 4 01 0A 06 00
367) 4921.5 Rx 0523 8 10 00 00 00 41 00 00 00
368) 4921.7 Rx 0523 8 62 00 00 00 50 00 00 00
369) 4922.0 Rx 0523 8 1C 00 00 00 50 00 00 00
370) 4922.0 Error 0004 4 01 0A 04 00
371) 4922.1 Error 0004 4 01 0A 05 00
372) 4922.2 Error 0004 4 01 0A 06 00
373) 4922.3 Error 0004 4 01 0A 07 00
374) 4922.4 Error 0004 4 01 0A 08 00
375) 4922.4 Error 0004 4 01 0A 09 00
376) 4922.6 Error 0004 4 01 0A 0A 00
377) 4922.6 Error 0004 4 01 0A 0B 00
378) 4922.7 Error 0004 4 01 0A 0C 00
379) 4922.8 Error 0004 4 01 0A 0D 00
380) 4922.9 Error 0004 4 01 0A 0E 00
381) 4923.0 Error 0004 4 01 0A 0F 00
382) 4923.1 Error 0004 4 01 0A 10 00
383) 4923.2 Error 0004 4 01 0A 11 00
384) 4923.3 Error 0004 4 01 0A 12 00
385) 4923.3 Error 0004 4 01 0A 13 00
386) 4923.4 Error 0004 4 01 0A 14 00
387) 4923.7 Rx 0523 8 9C 00 00 00 4F 00 00 00
388) 4923.7 Error 0004 4 01 0A 14 00
389) 4923.8 Error 0004 4 01 0A 15 00
390) 4924.1 Rx 0523 8 CC 00 00 00 41 00 00 00
391) 4924.1 Error 0004 4 01 0A 15 00
392) 4924.2 Error 0004 4 01 0A 16 00
393) 4924.3 Error 0004 4 01 0A 17 00
394) 4924.4 Error 0004 4 01 0A 18 00
395) 4924.4 Error 0004 4 01 0A 19 00
396) 4924.6 Error 0004 4 01 0A 1A 00
397) 4924.7 Error 0004 4 01 0A 1B 00
398) 4924.8 Rx 0525 6 86 73 AC 0D D0 02
399) 4925.0 Rx 0525 6 28 73 AC 0D D0 02
400) 4925.1 Error 0004 4 01 0A 1A 00
401) 4925.2 Error 0004 4 01 0A 1B 00
402) 4925.4 Rx 0525 6 4B 73 AC 0D D0 02
