I feel like I have a simple question that hopefully can be answered quite quickly. I have a 24V power supply that is supposed to achieve a max output of 200W. Recently, I have reason to believe that the supply has gone bad, and rather than damage anything down-line from this supply, I want to test the output with a dummy load.
Currently, I have just been making a dummy load by wiring a bunch of resistors in parallel, which gives me one net resistance of 13ohm (~45W of power). Ideally, I would like to make a dummy load that will cause the supply to consistently output ~80W of power. I feel like the bundle of resistors is really cumbersome, and that there is an easier way to do this, I am just unsure because I am a novice.
If anyone knows an easier way to make a dummy load that can undergo up to 200W, and is less cumbersome that would help me out a lot. Thanks!
