I'm doing my second ATX-to-bench supply conversion, and this time, I've decided to follow the "book" and place the correct minimum loads on all the rails instead of merely the 5V rail. This involves fairly small loads on the 3.3V rail and 5V rail (under 2W each), but a fairly sizable load on the 12V rail (12W). I've sourced very cheap cement resistors to provide the loads, but I understand that they are inductive loads, and I would like to know, will that cause a problem?
I assume it will not, because many of the loads in a normal computer are already inductive (HDD motors etc), but I would like confirmation from someone who knows a lot more about switching power supply design than I do.
