I broke it while trying to repair a nearby component on a 1970s board. It has two wires at one end that look like they are going to a coil and two axial wires. One of the axial wires came out with some pieces of glass.
The only markings are "P/F" which mostly likely means Philco/Ford.
The "silkscreen" was marked with "S1" and nothing else.
The end with the two coil wires is angled at 45 degrees I presume to indicate polarity.
I also need a way of working out what value it is so I can get a modern replacement.
