A LiFePo4 charging/discharging circuit (12 V, 200 Ah, 100 A max) is protected by a single coil latching relay with manual override. This relay is controlled by an ATMega328 (through a FET with flyback diode) but does not have state contacts. For safety and operational reasons, I would like to detect the open/close state of this relay and feed information back to the micro controller.
I have been so far considering measuring the differential voltage accross the contactor (<1 milliohm). This is somewhat simple but may fail if charging voltage equals the LiFePO4 battery (quite unlikely as CV/CC chargers will drive to ~14.4 V in absence of load). Contactor would be declared closed if voltage difference is less than 100 mV for some amount of time (~250 ms).
I am not certain of the type of differential amplifier and protections to use in these conditions:
- differential voltage range will be within -20 V/+20 V
- 50 V transients (+/-50 V) may exist during switching and load dumps
I would be very grateful if anyone could comment and criticize the approach and maybe advice on the kind of differential amplifier to select.
Best regards,
Edit:
