I'm totally unfamiliar with DC brushed motors but bought one for my watchmakers lathe. I was surprised how hard it is to rotate the spindle by hand and how noisy it is when running. With it running around 2000 rpm and my ear about 2" away from it, it sounds like a faint grinding noise.
So I took off the section with the brushes and the bearings seem perfect. But all four brushes have a raised rib contact surface and the commutator has rub marks that match the ribbed brush pattern.
I did some research on DC motors. One common remark was that brush contact surfaces must be smooth flat and shiny. So I did a search for ribbed contact surface brushes and nothing came up.
My questions are:
(1) Is it typically hard to turn the spindle by hand
(2) Could the brushes have been installed backwards, because the opposite end is smooth, flat and shiny. And there is no perceptible depth to rub marks on the commutator so I'm hoping the motor will be usable.
