I need help in understanding the factors that affect my battery selection for a device. I'd like to make this generic so that it is useful for others but I will use what I am designing for examples and clarity.
The goal is to design a small battery powered device worn by a child with a wrist whos surface area on top is 40mm by 20mm with a height of around 5mm.
I believe that I need to know the voltage required by the unit, the amount of time that the power will be provided, and how long I want the battery to last in order to figure out the battery I need.
The chip specs have this:
- Electrical Characteristics
- Output Power:
- Max. Power: 21 dBm
- Consumption @ LTE Cat M1 (Typical):
- Power Saving Mode: 3.2 μA
- Sleep Mode:
- 1.61 mA @ DRX = 1.28 s
- 0.61 mA @ e-I-DRX = 81.92 s
- Idle Mode:
- 19.6 mA @ DRX = 1.28 s
- 19 mA @ e-I-DRX = 81.92 s
- Active Mode: 228 mA @ 21dBm, GNSS off
- Consumption @ LTE Cat NB1 (Typical):
- Sleep State:
- 1.54 mA @ DRX = 1.28 s
- 0.66 mA @ e-I-DRX = 81.92 s
- Idle State:
- 15.8 mA @ DRX = 1.28 s
- 15.3 mA @ e-I-DRX = 81.92 s
- Active Mode:
- 165 mA @ 21dBm, GNSS off
- Output Power:
The device will need to connect to LTE-cat M1 or NB-iot, GNSS or gps to provide updates for location and geofencing.
I have two main points I am struggling with.
I would like an update every 15 seconds or so if the devices physical position has changed. Assuming the device is in use 25% of the time (6 hours/day) I am not sure how to calculate the power requirements per day that I could then use to say "I need a battery with voltage X that has Y amp hours to last Z hours."
Does gnss off mean this does not account for positioning data? if so, how do I account for that?
I have a design docs for the chip I am connecting too and I am only linking to it in case there is something I have missed here that helps. https://www.quectel.com/wp-content/uploads/pdfupload/Quectel_BG77_LPWA_Specification_V1.4.pdf
https://auroraevernet.ru/upload/iblock/f29/f2914b079245ebef14c2fc12799b0fdd.pdf
https://datasheet.octopart.com/BG77-Quectel-datasheet-139004296.pdf
