When I am using Thevenin's circuit and deriving inductor currents equations i am getting different Time constant \$ \tau\$ from what I am getting when I use Node Current analysis.
Here is my work for Thevenin's Circuit:-
\$from\ KVL :\$
\$V_{th} = i*R_{th} + L*\frac{di(t)}{dt}\$
\$\frac{V_{th}}{L}\ = i*\frac{R_{th}}{L}\ + \frac{di(t)}{dt}\$
Now after solving the homogeneous equation I get
\$i(t)= A*e^{-\frac{t}{\tau}\ \hspace{35pt} Where\: A\: is\: Constant}\$
\$ \tau = \frac{L}{R_{Th}}\ = \frac{0.8}{8}\ = 0.1s \$
This is what I am getting from Thevenin's equivalent circuit now Look at Original Circuit Equation
\$from\ KCL\: at\ node\: A :\$
\$ \frac{V_s-v}{R1}\ + \frac{0-v}{R2}\ - i = 0 \$
\$ \frac{V_s}{10}\ - v*(\ \frac{1}{10}\ +\frac{1}{40}\ ) - i =0 \$
\$ 8*v+i = \frac{V_s}{10}\ \$
\$ now\qquad v = L*\frac{di(t)}{dt}\ \$
\$ \frac{di(t)}{dt}\ + \frac{i}{8L}\ = \frac{V_s}{80L}\ \$
Now solving homogeneous equation
\$ \frac{di(t)}{dt}\ = - \frac{i}{8L}\ \$
\$ \tau = L*8 = 0.8*8 = 6.4s \$
Now here i am getting different \$ \tau \$ from what i get in Thevenin's circuit...also source is just constant. Please tell me where I'm making mistake.
  • \$\begingroup\$ Check the second approach \$\endgroup\$ Commented Aug 4, 2021 at 20:21
  • \$\begingroup\$ @HariKrishna have i made some mistake in it ? \$\endgroup\$
    – fpsshubham
    Commented Aug 4, 2021 at 20:24
  • \$\begingroup\$ Check my answer , and see if its coming correctly \$\endgroup\$ Commented Aug 4, 2021 at 20:25
  • \$\begingroup\$ The current flowing through the inductor at t->infinity is 1A .8Ω is the resistance seen by the inductor.So the final equation for inductor current is:IL(t)=1(1-e^(-10t)) so the time costant is 0.1s \$\endgroup\$
    – Miss Mulan
    Commented Aug 4, 2021 at 20:55
Your first approach is correct. Second one, you took the KCL at node A (correct) but then two lines from there its V/8 but you wrote it V*8
PS: \$-V(\frac{1}{10} + \frac{1}{40}) = -\frac{V}{8} \$ ; not -V8!!!
  • \$\begingroup\$ Ohhh ok i understand all this time i was inversing 1/8 because i was thinking about parallel resistance!!! \$\endgroup\$
    – fpsshubham
    Commented Aug 4, 2021 at 20:29
  • \$\begingroup\$ Yea it should be matching now \$\endgroup\$ Commented Aug 4, 2021 at 20:31
