I'm wondering if I have my car battery hooked up to a power inverter hooked up to a battery maintainer hooked up to the same car battery will it prevent me from needing to jumper cable my car?
I often deplete my car's battery As I live in my car. If on occasion I fall asleep with the car in accessory mode and wake up to a dead battery. So I'm wondering if this setup will assist my alternator in keeping the battery fully charged or is this just a waste of time or even worse is it dangerous?
I have multiple car batteries and I and I'm playing with the ideas of ideas of hooking up a second battery and wiring them in parallel. But I have limited funds and limited knowledge in this field. I have appropriate gaged wires and tools. I know how to splice crimp spider determine positive/negative just to give you an idea of my capabilities.
I currently have a 750 and 450 watt inverter. I drilled through the fire wall to run cables into the car and the inverter run all of my devices. Thank you in advanced for even taking the time to read my question(s).
