I have a RC receiver that produces a PWM signal for hobby servos (specs below). I would like to control some LED lighting with it. What are my options? I obviously do care about weight, like I do about functionality.
The setup is as follows:
The PWM specs are as explained at https://en.wikipedia.org/wiki/Servo_control -- 5V, 50 Hz, pulse width 1000 μs for OFF, 2000 μs for ON. I plan to use current-regulating LEDs rated 5 to 20 V as I don't need to dim them, but if a dimming option is available with output voltage e.g. 0 to 5 V, I'll happily switch to some common 3.1 V LEDs + resistors.
I feel like I cannot be the first one facing this issue, but I can't find any commercial solution, possibly because I don't know what I'm looking for.
