I am embarking on a robotics project. As a part of that I will be connecting two motors to a motor controller designed for two (+1) motors. Each motor has voltage 6-12 V and the motor controller has 5-24 V.
My question is how does the motor controller distribute voltage from the power supply? If I connect 24 V to it, will that be too much for my motors? Or will it be evenly distributed between them?
Here are the motors I am using: Premium N20 Gear Motor (298:1 Ratio, 90 RPM)
And here is the motor controller: TReX Jr Dual Motor Controller
Sorry if the question is basic, I am just getting into this and trying to understand what means what.
Edit: Thank you for the answer!
