Which transistor and diode is suitable for fast switching power and low discharge battery when Vin, for PWM 1.2-29 KHz, 4 A, 3.7-5 V?
And which capacitor should be at the output to smooth the switching time?
  • Battery: 18650, 3.7 V, 2500 mAh;
  • Vin: 5 V, 5 A, Wall-DC;
  • Vout: PWM, 95% duty cycle, 1.2-29 Khz pulse of 3500 mA
  • Can I use IRLML2244TRPbF ?
  • \$\begingroup\$ The LTC4054 is a "Linear Li-Ion Battery Charger". Where does PWM come into the circuit? \$\endgroup\$ Commented Nov 28, 2021 at 18:06
  • \$\begingroup\$ PWM is a load, Vout \$\endgroup\$
    – Andre
    Commented Nov 29, 2021 at 3:42
  • \$\begingroup\$ So you want to build the circuit more or less as shown but just want to know what Q1 and D2 you should use? What is connected to VOUT doesn't really matter, does it? I am afraid the way your question is written, it sounds like a "shopping" question. Maybe you can rewrite it so you are asking about what parameters to look for in selecting D2 and Q1 instead of asking for a specific part. Maybe that would keep it from getting closed. \$\endgroup\$
    – user57037
    Commented Nov 29, 2021 at 8:37
  • \$\begingroup\$ I do not know which parameters Q1 and D2 are important for this load. If I knew, I would have matched Q1 and D2. What parameters should I pay attention to? \$\endgroup\$
    – Andre
    Commented Nov 29, 2021 at 8:43
I've found MCP73871 with 1800mA max output. It's not 3500 mA, but it's enough for me for now. enter image description here
