I am currently embarking on a project that requires 4 brushless motors. Let's say the KV rating for each motor is 1400kv and requires a 30 A bi-directional ESC for each motor, and that I want to power it using a SINGLE power source which is 12 V, 30 A.
I know I can solder all the positives together and connect it to the positive and all the negatives to the negative and the ESCs would receive power and would power the motors.
My question is: what is the effect of connecting multiple motors to ONE power supply like this? Do they start sharing current? Will it affect the RPM/performance? For example, when you add more brushless motors, will this start affecting the performance of the other motors? Does the 12 V get divided by 4 - because I am connecting 4 brushless motors? Is the case the same with the amp rating; does it get divided?
If it will, is it better that I buy a regulated bench power supply so I can control the V and A ratings?
I have a follow up questions. I am now looking to purchase DC 12V 83.3A 1000W Power Supply and will use 4 brushless motors A2212 1400KV Brushless Motor. I have checked the Motors and they require 11.1 V and Load Current: 19.0A Power:210W. From my understanding the power supply I am looking to purchase would meet the requirements to run the motors at full torque. Am I correct is the power supply adequate or am I missing something?
