You have to visualize the circuit properly as an abstract network (graph) consisting of nodes and edges. The edges go through components and the nodes are where components join.
Imagine a capacitor connected to a battery: a two component circuit. That circuit has two nodes: node N0 where the - terminal of the battery meets with a terminal of the capacitor, and node N1 where the + terminal of the battery meets the other terminal of the capacitor. We would usually identify some particular node, like N0, as a special node through which currents return and from which we measure voltage.
Now would you say that \$V_B - V_C\$ or would you say that \$V_B = -V_C\$?
Of course when we are reading the schematic, we equate the two voltages! Both components are connected between exactly the same two nodes: from N0, to N1. It is because the two are equal that no current flows: we have equi librium.
But in order to apply the voltage and current laws, we have to follow complete circuits through the network. The voltage law does not work in terms of \$V_B\$ or \$V_C\$ but rather in terms of the nodes. As we go around the circuit, starting and ending on the same note, we arrive at the same potential: we do not lose or gain any net energy. This is because the electric field is a conservative field. Suppose we are positive electric charge starting our trip at N0. In moving from N0 to N1 across the battery, we gain potential. Then returning across the capacitor from N1 to N0, we lose the same amount of potential. Net potential gain: zero.
If you climb over a mountain's east side and come back down the west side to the same elevation, you do not say that the mountain has a negative height on the western side! The mountain is just as tall from the eastern basecamp as as it is from the western one. What is negative is your change in gravitational potential along the path which goes up and then down.
Note that if you reverse the path through the circuit, then the capacitor is regarded as being positive. But there is no preferred path. There is no reason to evaluate the path integral of the electric field in one direction versus the other. It works for all circuits in the network, regardless of their orientation. You can work the voltage law with the current (if there is any) or against the current. It doesn't matter. In the circuit in which a battery is connected to a capacitor (and has been for a long time), no current flows. You can trace the circuit up the capacitor and down the battery, or up the battery and down the capacitor.
If there are three nodes in the circuit, and we traverse it N0 -> N1 -> N2 -> N0, then the voltage law tells us that (N1 - N0) + (N2 - N1) + (N0 - N2) = 0. And in fact, the left formula in this equation works out to be zero, algebraically! That's really what the law is about: it is connected to electric potential being a conservative field, and therefore behaving like an algebraic field which lets us calculate easily with voltages.
The current law is also expressed in terms of nodes and is even simpler, because it applies entirely locally: the total of the currents flowing into and out of every node is zero.
