I have basic question about connecting two batteries of same type (ie of same voltage and same capacity, say 12V and 100Ah) parallel.
A usual rule of thumb says that if with connect two batteries of same type (Y V, X Ah) in
-series, the "composed" battery twice as big
voltage \$2Y\$, but same capacity \$X\$
-parallel, then the "composed" battery has same
voltage \$Y \$, but twice as big capacity \$2X \$
I prepared some calculations in order do derive the predicted rule of thumb for the series case based on elementary Kirchhoff's circuit laws. while the addition of voltages results as an immediate consequence, I not see how I can conclude from consideration below the prediction that the capacity of the two batteries in series is the same as for single battery.
Setting: to apply Kirchhoff laws we should assume that our battery V has small internal resistence \$ Ri \$. let moreover R the a test / load resistance. For a single battery we have:
By kcl's we obtain
$$ U_R= V- U_{Ri} \approx V $$ and
$$I =U_R/R= (V-U_{Ri})/R \approx V/R $$ since \$Ri\$ and \$ U_{Ri} \$ are considered to be "small" (\$ R_i << R, U_{Ri} << V, U_R \$)
Let now think about serial case with two batteries 1 & 2 of same type and same load resistance \$R\$:
We conclude with kcl's
$$ U_{R,S} = U1+U2 -U_{Ri,1}- U_{Ri,2} \approx U1 +U2 =2V$$
and
$$ I_S = U_{R,S}/R \approx (U1+U2)/R = U1/R + U1/R = 2 V/R \approx 2I $$
since the voltage of the parallel bank battery \$U_{BB,S} \$ is nearly \$ U_{R,S} \approx U1+U2 =2V\$ that's consistent with serial thumb rule.
But how can we derive from \$I_S=2I\$ that the capacity of serial bank battery stays the same as for a single battery?
