I would like to ask a question regarding the current prototype I am designing for a monitoring system using Raspberry Pi, an ADS1115 ADC and analog/digital sensors. Below is the schematic of my current prototype
I am powering two analog sensors (PH-4502C, TDS Meter Gravity) at +5V, a DS18B20 digital temp sensor at +3.3v, and float switch sensors at +3.3v as well using a MB102 power supply. I chose this since I'd rather have external power for powering this prototype to reduce sourcing too much power from my RPI for this node as I consider integrating it with other circuitry to build larger systems in the future. The MB102 is also powered using a 12v 1A adapter.
My question lies with the ADS1115 ADC. I am considering in powering it also from the +3.3v off the external supply, however, I am not sure if what other considerations should I look into aside from the VDD I am supplying to ensure accurate readings are being made.
With that, my questions are as follows:
1.) Is the direct +3.3v supply to the ADC appropriate? Would I be better off on using the RPI +3.3v pin instead?
2.) In context with 1, do I provide common ground with the RPI using the MB102 ground? or with the +12v ground? What would be the difference in this case?
3.) Would I need extra components for somehow creating a more stable and safe circuit for my sensors, ADC, and the RPI?
4.) I am also looking into using a CAT5E cable for extending the wiring off the RPI to the prototype with maximum length of 1 meter. How would this affect the quality of data transmission from ADC to the controller? Would direct connection still be okay as it is?
Datasheets for reference:
PH4502C pH meter Sorry but I couldn't find a proper datasheet for this so here is another reference link instead
