The power supply of my home lighting keeps failing. So far I have had ten identical power supplies fail. Upon inspection the thing that is always damaged is the electrolytic capacitor after the bridge rectifier (the power supply has no step-down transformer). I have always fixed the faulty capacitors by replacing them with new ones.
Aside from the power supply just being badly designed, I can only think of two reasons why they are failing: from getting too hot, or from surge voltages.
I can't really fix the temperature problem with how things are; the only thing I can do is buy electrolytic capacitors that are rated to survive in that environment; 10000 hours @ 100°C and from surge voltages that exceed the capacitor's voltage rating. I'm pretty sure they are using very cheap capacitors - that's why they are failing so fast.
To solve the surge problem I am thinking of placing a MOV on the AC input of the circuit so that the capacitor and the bridge rectifier won't be exposed to surges. The original circuit does not have any protection against surges. I was wondering if my adding MOVs to the circuit can cause problems, because I am essentially modifying the circuit. I don't think there will be, but I am just making sure.
