I'm fairly new to circuit design, so excuse me for asking maybe a noob question; I did some research, but because of my lack of understanding I'm not quite sure if my conclusion is the right one.
I have a simple circuit with a high voltage input (24 V), a step down converter with components (XL1509 3.3 V), and an ESP32.
When I read the datasheet of the XL1509, I read the minimum current is 0.2 A. Running the ESP32, the current necessary is below this 0.2 A.
My question:
How can I increase the current to at least 0.2 A, so the step-down converter will work properly? I think I need like a 16.5 Ω resistor (3.3/0.2). Is this a correct assumption?
My second question regarding this: I'm not married to the XL1509, an other step-down converter will also do, but all step-down converters that can go from 24 V to 3.3 V have a minimum load of 0.2 A. Am I missing something?
And, is, for the above circuit (efficiency wise) a linear regulator maybe a better idea? The ESP32 is the only component (besides the regulator and its assisting components) in my circuit.
