There is a galvo-mirror which needs the following analog inputs:
DAQ boards are expensive and seems overkill to me.
I can live with 12-bit so I was planning to use a microcontroller board which has two 12-bit DACs with 0V-3.3V range. But I can only create diff signals as shown on the left below. But I need the signals as shown the right side below:
So I both need voltage amplification and bipolar outputs from my micro's outputs. What should I look for as specs and device in such a case? Only fully diff amplifier came to my mind after a quick search. Can that be the correct approach to handle this problem? And I tried to find a fully diff amplifier and couldn't find anything in DIP package which I can only solder.
edit for a comment:
- then don't state what an undesirable DAQ solution might be; state what is needed for the device. \$\endgroup\$
