I am planning to use the Maxim Current Sense Amplifier(MAX9634HEUK+T)with a gain of 100V/1V implemented as HIGH-SIDE to measure the system current in both normal working mode and sleep mode.
I am using a Shunt Resistor of around 1R.
In normal operation the device consumes around 200mA MAX operating at 3.3V. So I am calculating a Vsense=0.2A*1R= 0.2V or 200mV
However, in sleep mode, the device draws a maximum of 200uA that gives a Vsense=0.0002A*1R=0.2mV
Q. What size of shunt resistor should I choose to accurately measure current as low as 200uA and as high as 200mA?
Q. The MAX9634HEUK+T has a max offset voltage value of 250uV meaning I won't be able to accurately measure the device current when it operates in sleep mode.
Q. The MAX9634HEUK+T comes with various gain options. What gain version should I select along with the shunt resistor to accurately and efficiently measure the current in both normal and sleep mode?
