I have an IC with integrated gate driver. This IC has an integrated logic, charge pump and gate driver section.
Unfortunately, the rated voltage of my application is higher than the ICs rated voltage. I was wondering if I could add gate drivers that can switch an H-bridge at a higher voltage and make it work for my application.
I have figured out how to wire up the bottom side outputs of the gate driver, but I can't figure out where to connect the floating pin of the high side gate driver to get the system to work.
Has anyone else done this before?
I'll add more details: I am trying to drive the MP1906 gate driver from the output of a BLDC predriver IC. Here is the block diagram of the BLDC predriver gate driver section.
Here is the pinout of the MP1906 gate driver:
I figured out that I need to connect the GLx pin to the LPWM pin on MP1960 and GHx to HPWM but how should I connect the SHx pin to get the system to work correctly?
