I tried to use IGBT (skm400ga-12t4) to do fast current switching of circuits with an inductor. The gate driver used adum4121-ARIZ and gate driving was performed by making a same circuit to the example in the data sheet.
Currently, one of the four IGBTs I have had was fine with gate driving even if 150A current was applied to the coil, but the other three had problem. Symptoms of three problematic IGBTs are as follows.
Gate driving works well up to 30A, so I think the gate driver needs protection or I use it more than specifications of parts (IGBT or gate driver), but I don't know where the problem is. The current flowing through the coil (inductor) did not have a problem up to 30A, but adum-4121 shows problem around 50A, and Vout only came out at 3V. Even if I changed the gate driver, it broke down again. I checked that gate driver worked well at first and the ampere was output properly when I applied 50A or higher. However, gate driving did not work properly when the second test was conducted, and the reason was that Vout is only 3V. Maybe the gate driver will have a problem when the current decreases.
Gate driving works well up to 30A, so I think the gate driver needs protection or I use it more than specifications of parts (IGBT or gate driver), but I don't know where the problem is. Of course other possibilities may be the 3 IGBTs problem. But it's so strange that 3 out of 4 have functional defects.
Could you help me find out what the problem is?
schematic figure of circuit
You are driving the gate to emitter with 5 volts. Examine the data sheet and you will find that the gate emitter requires more than 11 volts to turn on fully.
Typically the IGBT will use 15 volts for proper operation.
Your schematic also shows no connection for the emitter ground to your driver. But I suspect you do have the connection.
You can also use an oscilloscope to observe the Vce at turn off, to reassure yourself that you are not exceeding the maximum collector emitter voltage.
  • \$\begingroup\$ The gate emitter voltage is 12V. The gate driver needs GND1 and GND2 for isolation, and the gate voltage follows the voltage difference between GND2 and Vdd2. The emitter is connected to the emitter of the IGBT. I didn't draw it by mistake. I will check with the oscilloscope today. Thanks for the advice. \$\endgroup\$ Commented Apr 13, 2022 at 3:04
  • \$\begingroup\$ Thanks. I think the reverse voltage on the CE is too high and the diode in the IGBT is broken. There was no problem when I tried using a varistor with a low voltage and another IGBT. \$\endgroup\$ Commented Apr 13, 2022 at 9:47
