I am currently in the process of interfacing with a CH101 ultrasonic sensor. I am using a nucleo STM32 board, with some level shifters for communication with the sensor. I am able to successfully perform the initial connectivity check (Reading from device address 0x45, memory address 0x00 - returns 0x0A 0x02) as per the documentation, and ch_group_start appears to write the firmware to the device. However after writing the firmware I cannot progress further.
The culprit seems to be the ch_common_get_locked_state. I can see that it's attempting to read from the assigned I2C address, but the communication seems to break every time. It should be reading a single byte from I2C address 0x29, register 0x14. I think the sensor might be holding the SDA line low for some reason.
I'm not sure if anyone has experience with this sensor and issues after writing the firmware.
This seemed to be an issue with the level shifting board I was using. Swapping it out fixed things luckily!
