First of all, I'm a total novice.
My parents have an old electric curtain pulley system from probably the 70's. It's run by a universal motor connected to a 3-position switch. The switch positions are OFF - LEFT - RIGHT. 3 wires run from the switch to the motor (common black, plus a blue and a brown from the switch positions).
By inspecting the wiring, it looks like it just runs the universal motor forwards or reverse by engaging only one of the two stator coils (the blue wire runs to one stator coil and the brown wire runs to the other one). Both stator coils share the same black wire (I'm assuming it's the live wire - it runs through an old capacitor/filter thing first and in series with the rotor).
I want to toss the awful, ancient, noisy spark-frenzy fire hazard of a motor and replace it with a quiet DC motor. The old motor is rated 200/90W whatever that means. I would like to keep the switch though, so my question is: How do I control the direction of a DC motor using AC wires - one live wire and two neutrals?
Many thanks in advance :-)
edit: It's actually only 2 wires coming from the switch to the motor. The common live wire is just from the wall.
Here's the current schematic:
Here's an attempt at a solution. It's probably pretty naive. And if someone could tell me if a relay can be controlled with an AC signal or not, that would be great.
Somebody said relays couldn't be wired in series with the transformer, so here's another attempt using two relays: Please tell me if it would work.
edited: cleaned it up a little
