I have a 400V three-phase [TT system][1] that I use for my company in Italy. I was wondering if there is a direct way to detect the phase number at any point in the wiring.
I have the phases numbered at the meter as L1, L2, L3. What I'd like to do is to test a random line in the downstream wiring and detect if it's L1, L2 or L3.
I have a phase rotation meter and I know that I can test if the rotation is correct at any point (it is, since everything works as it should), but as far as I know the phase rotation can be correct even if the phases are i.e. in the sequence L3, L1, L2. I'd like to know if that's the case at any point in the wiring.
The reasoning behind this test is that I have a solar array which is unbalanced on the three phases. I want to move some of the single phase loads where I have more solar power, to avoid sourcing power from the grid when I have it available on other phases of my solar array. A second minor reason is to have consistent wiring colors everywhere, to avoid running in the same issue in the future.
I can figure out what I need to know with a bit of indirect tests, but I was wondering if there is a clever or faster way to test it directly on the wire. [1]: https://en.wikipedia.org/wiki/Earthing_system#TT_network
