On my pcb I need a 2-pin female wire-to-board connector on which 120V DC will arrive.
What is the standard way to approach this? (I got this one for example)
Thanks!
Thanks!
Do not use a female connector for a power inlet: the male plug for it is unsafe.
Instead, use a female plug on the power cord and a male inlet on your board.
Any wire-to-board connector with a pitch of greater than 2.54 mm will work. A standard solution is a 3.96 mm pitch, single-wall, wire-to-board connector. (My site.)
The volatge rating can be increased by skipping the middle pin (as shown in this picture). The plug in this picture is latched, though unlatched plugs are more common.
You can buy the male PCB header here and the female plug housing here.
