It seems the reset pin on the NE555 is connected to a PNP which could be left open instead of to upper rail.
What are the drawbacks of leaving the reset pin floating?
Can the NE555 reset pin remain floating?
From the data sheet you linked (at the bottom of page 8): -
From the Diodes Inc data sheet (page 7): -
And, just in case the recommendations for connecting the reset pin to Vcc are a recent thing, here is a picture of the 1973 Signetics data sheet (page 9): -
Maybe there is a 1972 version when the device first came out that someone can find?
Drawback is it might not work at all, or it might work intermittently or unreliably.
Direct quote from TI NE555 data sheet:
To prevent false triggering, when RESET is not used, it should be connected to VCC.
The above quote is identical with what reads in Diodes Incorporated NE555 data sheet.
Direct quote from ST NE555 data sheet:
When Reset is not used, it should be tied high to avoid any possibility of unwanted triggering
Even if you have never had a problem leaving it open, it does not mean it is a good idea to leave it open as it might not always work.
On the balance, I think there’s no reason not to connect it.
