I have a short (<1 s) pulse output that will be around 20 kV. Frequency is around 100-200 kHz. How would I make a coil that induces the biggest electromagnetic force (to radiate and mess with the internal circuitry of calculators).
My train of thought: According to Faradays law:
(if you substitute dΦ with B*dA):
if you substitute B with (U0I)/2pi*d, where you bring down 2pid to the denominator and fill in 1.26 *10^-6 for u0 (permeability of free space).
In conclusion this would mean that a bigger turns ratio N and a higher current along a shorter time would mean a higher EMF (logically).
But if you would look at the equation for the impedance you would not want a too high turn ratio because this would increase the inductance and thereby the impedance which would decrease the current.
Is this analysis correct? And what should you do with the inductor/coil to get a maximum EMF?
Schematic of used system:
