I'm using this MIC23150-4YMT-TR with fixed output voltage.
On the PCB, I tested the output & found that it is 2.6V and not 1.2V. I checked it on 3 PCBs and all show the same result
Schematics:
Schematics:
From labelling I assume the input voltage is 3.3V.
The output is sampled with an on-chip divider (Let's called the resistances R1 and R2 – R1 from output, and R2 to ground) and compared to an internal reference voltage (Vref). So the output voltage will be VOUT = Vref × (1 + R1 / R2).
If there's any resistance on the feedback path (i.e. from output to SNS pin) then the final output voltage will be higher because this resistance will be in series with R1. If this path is open then the chip can't see any feedback so it will constantly increase the duty cycle until it hits pre-defined limit of 80% (Nothing is mentioned about open loop protection so it's quite likely to happen). In this case the output voltage can be as high as VOUT = 3.3V × 0.8 = 2.6V.
Make sure the output connects to the SNS pin. It may not be easy to check as the pin doesn't seem to be easy-access.
