Development environment
I'm working with STM32F427 and I use Keil uVision V5.29 to develop my application. The version of the ArmCLang Compiler, of the Assembler and the linker is 6.131.1.
Scatter file and __attribute__
directive
I need to allocate some variables in the SRAM into the address interval:
[0x20000000, 0x20030000]
The variables are at least the following:
ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT];
ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT];
I have tried with the __attribute__
directive as following:
ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT] __attribute__((section(".ram1")));
ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT] __attribute__((section(".ram1")));
I have defined the following scatter file:
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x08000000 0x00200000 { ; load region size_region
ER_IROM1 0x08000000 0x00200000 { ; load address = execution address
*.o (RESET, +First)
*(InRoot$$Sections)
.ANY (+RO)
.ANY (+XO)
RW_IRAM1 0x20000000 0x00030000 { ; RW data
*(.ram1)
RW_IRAM2 0x10000000 0x00010000 { ; CCM
.ANY (+RW +ZI)
Compilation error
If I compile the project with the previous scatter file (with or without the __attribute__
directive) the compilation output shoes many of the following error:
...: Error: L6406E: No space in execution regions with .ANY selector matching app_azure_rtos.o(.bss.variable_name).
My question
Where is it the error in the previous scatter file?
EDIT
I have found this link which suggests that there is not enough resource for the program.
But if I use the following scatter file (where it is completely excluded the CCM memory and this means that 56 Kbytes of RAM are not used):
*.o (RESET, +First)
*(InRoot$$Sections)
.ANY (+RO)
.ANY (+XO)
.ANY (+RW +ZI)
the compilation ends successfully. This means that the problem is in the scatter file not in the memory resources.
