I am designing a PCB board and was wondering if there is a reason not to use ring terminals directly to a PCB. The PCB could have a pad surrounding a hole like I often see as ground connections. A small bolt could go through the PCB with two nuts, one holding it to the board, and another to hold the ring terminal down.
I've tried those little green screw terminal things where you can stick a wire in the side and screw down the top, but they always seemed flimsy for the relatively big wire I am using. I've also tried terminal blocks where one side has a wire soldered to the PCB and the other side can be connected to with a ring or spade terminal, but that seems like extra work when the PCB could be designed to screw to directly.
Just wanted to check if I was missing anything obvious here as to why not to do this.
