I am designing a power amplifier with RA60H4047 UHF module. I am designing the schematic for driver circuit. It is a two way power amplifier (the transmission and reception paths are different.)
Normally people design with a relay in both input and output to avoid mixing receive signal from the antenna with the RA60h transmission.
A relay creates chatter and I think a diode on the output of RA60 should be good enough to prevents mixing the signals.
The output of the RA60H4047 is 60-80 W based on bias current and frequency range (400-470 MHz).
What diode can I use for this application?
The voltage I am providing for 60 W output is 13.5 V.
