The switched mode power supply controller IC contains a feedback loop. The output voltage goes into a voltage divider resistor circuit and the output from this voltage divider goes into the controller IC again.
I have three questions that have a very specific answer.
- Feedback signal has amplitude but also a frequency due to noise or other factors. What do we do about frequency response of this feedback path? Does it require special analysis and care?
- Besides white noise and the actual switching activity of the SMPS system, what else can introduce AC component into the feedback signal?
- Must the resistor value be in kohm, or it could be ohm or mega ohm as well?
