I've got a single phase inductive motor rated at 1.1 kW, 220 - 240 V, and 7.1 A.
Can I safely connect this motor to a WiFi switch rated to handle 100 - 240 V and 10 A?
Clearly the switch can handle the rated current, but what about the ~6x inrush current when the motor turns on? Does the rating for the switch allow for very short overcurrents?
Followup question: if the answer is no, I can't safely use this switch, must I find a switch/relay rated to handle ~40 A?
Thank you very much for the help!
EDIT: The spec sheet can be found at http://sonoff.tech/wp-content/uploads/2021/03/%E4%BA%A7%E5%93%81%E5%8F%82%E6%95%B0%E8%A1%A8-BASICR2-RFR2-20201218-1.pdf, the full manual at http://sonoff.tech/wp-content/uploads/2021/03/%E8%AF%B4%E6%98%8E%E4%B9%A6-BASICR2-RFR2-V1.2-20210305-1.pdf, and the general webpage for the device at https://sonoff.tech/product/diy-smart-switches/basicr2/
