I need to change between heating and cooling with a Peltier, controlling this with PID. I've read a ton of information on Peltiers, looked at their datasheets and despite of this, I still cannot understand some things. First - is the Peltier heat transfer rate linear to the current? I am looking at this chart:
This chart is for given Thot, and the curves are for different dT. But since when you change the current dT is changing, in the reality Qc should follow some other curve. But I cannot understand how it should look. Will it be straight? Will it depends on Thot?
I'm not even sure that if I'm interested in Qc linarity, because in an actual system we control the temperature, so probably I should be more interested in the proportionality between the current and dT(hot-cold). But since the heat losses of the cooled volume will be proportional to the difference between the inside and ambient temperature, equal amount of Qc won't change the same amount of dT at different inside temperatures. I feel really confused :)
So the dissipated heat is the sum of transferred heat and resistance generated heat, which increases with the square of the current. Here too, I cannot understand how will this look in actual operational conditions.
I'm trying to understand all this, for two reasons - first I will have to determine if I have to change PID constants depending on some conditions (as dT, Thot and I). And second - I have to find a way to linearize the dissipated heat at the hot side and to drive the current is a way that gives me equal or at least similar curves on both sides.
