I am bit out of ideas for this SMD fuse marked with "PP", where I can only find "P" ones. It's about 2x1mm in size. Does anyone have a clue what that is? Maybe its no fuse, after all ;) Thanks!
2\$\begingroup\$ It'd be easier to help you if you provided a photo of the component. along with its dimensions. \$\endgroup\$– uriyabscCommented Aug 3, 2023 at 7:15
1\$\begingroup\$ Sure, here you are: imgur.com/a/SnvVtRX - Its about 2x1mm in size \$\endgroup\$– flohackCommented Aug 3, 2023 at 7:45
Add a comment
1 Answer
\$\begingroup\$ It seems to make sense in this case, as this is an electric toothbrush the motor probably can draw a few 1-2 amps at low voltage. I will mark the question as answered. \$\endgroup\$– flohackCommented Aug 3, 2023 at 9:09
