I am bit out of ideas for this SMD fuse marked with "PP", where I can only find "P" ones. It's about 2x1mm in size. Does anyone have a clue what that is? Maybe its no fuse, after all ;) Thanks!
Picture of unknown fuse
    \$\begingroup\$ It'd be easier to help you if you provided a photo of the component. along with its dimensions. \$\endgroup\$
    – uriyabsc
    Commented Aug 3, 2023 at 7:15
    \$\begingroup\$ Sure, here you are: imgur.com/a/SnvVtRX - Its about 2x1mm in size \$\endgroup\$
    – flohack
    Commented Aug 3, 2023 at 7:45
Probably a Bourns MF-PSML300 PTC resettable fuse. enter image description here enter image description here
  • \$\begingroup\$ Thanks mate, I will check! :) \$\endgroup\$
    – flohack
    Commented Aug 3, 2023 at 8:18
  • \$\begingroup\$ It seems to make sense in this case, as this is an electric toothbrush the motor probably can draw a few 1-2 amps at low voltage. I will mark the question as answered. \$\endgroup\$
    – flohack
    Commented Aug 3, 2023 at 9:09
