First, I will present a method that uses Mathematica to solve this problem.
Well, we are trying to analyze the following circuit:
When we use and apply KCL, we can write the following set of equations:
$$\begin{cases}
\begin{alignat*}{1}
\text{I}_\text{a}&=\text{I}_0+\text{I}_4\\
\text{I}_0&=\text{I}_2+\text{I}_3\\
\text{I}_1&=\text{I}_2+\text{I}_4\\
\text{I}_\text{a}&=\text{I}_1+\text{I}_3
\end{alignat*}
\end{cases}\tag1$$
When we use and apply Ohm's law, we can write the following set of equations:
$$\begin{cases}
\begin{alignat*}{1}
\text{I}_1&=\frac{\displaystyle\text{V}_1-0}{\displaystyle\text{R}_1}\\
\text{I}_2&=\frac{\displaystyle\text{V}_2-\text{V}_1}{\displaystyle\text{R}_2}\\
\text{I}_3&=\frac{\displaystyle\text{V}_2-0}{\displaystyle\text{R}_3}\\
\text{I}_4&=\frac{\displaystyle\text{V}_2-\text{V}_3}{\displaystyle\text{R}_4}
\end{alignat*}
\end{cases}\tag2$$
We also know that \$\displaystyle\text{V}_1-\text{V}_3=\text{V}_\text{i}\$.
Now, we can solve for \$\displaystyle\text{V}_2-\text{V}_1\$:
$$\text{V}_2-\text{V}_1=\frac{\displaystyle\text{R}_2\left(\text{I}_\text{a}\text{R}_3\text{R}_4-\text{V}_\text{i}\left(\text{R}_1+\text{R}_3\right)\right)}{\displaystyle\text{R}_2\left(\text{R}_1+\text{R}_3\right)+\text{R}_4\left(\text{R}_1+\text{R}_2+\text{R}_3\right)}\tag3$$
Where I used the following Mathematica code to find \$(3)\$:
In[1]:=Clear["Global`*"];
solution =
FullSimplify[
Solve[{Ia == I0 + I4, I0 == I2 + I3, I1 == I2 + I4, Ia == I1 + I3,
I1 == (V1 - 0)/R1, I2 == (V2 - V1)/R2, I3 == (V2 - 0)/R3,
I4 == (V2 - V3)/R4, V1 - V3 == Vi}, {I0, I1, I2, I3, I4, V1, V2,
V3}]];
FullSimplify[(V2 /. solution[[1]]) - (V1 /. solution[[1]])]
Out[1]=(Ia R2 R3 R4 - R2 (R1 + R3) Vi)/(R2 (R1 + R3) + (R1 + R2 + R3) R4)
So, the power in the resistor \$\text{R}_2\$ is given by:
$$\text{P}_{\text{R}_2}=\frac{\displaystyle\left(\text{V}_2-\text{V}_1\right)^2}{\displaystyle\text{R}_2}=\text{R}_2\left(\frac{\displaystyle\text{I}_\text{a}\text{R}_3\text{R}_4-\text{V}_\text{i}\left(\text{R}_1+\text{R}_3\right)}{\displaystyle\text{R}_2\left(\text{R}_1+\text{R}_3\right)+\text{R}_4\left(\text{R}_1+\text{R}_2+\text{R}_3\right)}\right)^2\tag4$$
In order to find the maximum, we can use:
$$\frac{\displaystyle\partial\text{P}_{\text{R}_2}}{\displaystyle\partial\text{R}_2}=0\space\Longleftrightarrow\space\text{R}_2=\frac{\displaystyle\text{R}_4\left(\text{R}_1+\text{R}_3\right)}{\displaystyle\text{R}_1+\text{R}_3+\text{R}_4}\tag5$$
Where I used the following Mathematica code to find \$(5)\$:
In[2]:=FullSimplify[
Solve[{D[(
R2 (Ia R3 R4 - (R1 + R3) Vi)^2)/(R2 (R1 + R3) + (R1 + R2 +
R3) R4)^2, R2] == 0}, R2]]
Out[2]={{R2 -> ((R1 + R3) R4)/(R1 + R3 + R4)}}
Using your values, we get:
$$\text{R}_2=\frac{\displaystyle2000\left(3000+1000\right)}{\displaystyle3000+1000+2000}=\frac{\displaystyle4000}{\displaystyle3}\approx1333.33\space\Omega\tag6$$
And the power is:
$$\text{P}_{\text{R}_2}=\frac{\displaystyle3}{\displaystyle16000}\approx0.0001875\space\text{W}\tag7$$
