Can anyone help me identify this IC?
It's inside a Camranger 2 next to a USB and ethernet port. It's overheating.
  • \$\begingroup\$ It may just be the lighting, but C837 looks suspiciously shiny to me. Can you check it with a multimeter to see if it is short-circuited? (The component identifiers are in that block of printing; for position, U22 is the IC in question.) \$\endgroup\$ Commented Sep 26, 2023 at 12:49
    \$\begingroup\$ How do you know it is overheating? Did you measure it somehow? \$\endgroup\$
    – Lundin
    Commented Sep 26, 2023 at 13:59
It's most likely an MP65151DJ from Monolithic Power Systems. For reference from the datasheet (pdf):
Screenshot of MP65151DJ datasheet, showing top marking information and pinout
Note the top marking of "AAN" for an active-high single switch TSOT23-6 chip. Package information from MPS for a TSOT23-6 package (pdf) indicates that the vertical line is the polarity/pin-1 indicator, the first three letters are the package code, and the last letter is a date code.
Top marking encoding schema from MPS document
From an MPS document detailing the date code (pdf), it looks like "J" means your part was made in 2018.
The circuit on your board seems to match the pinout as well (pin 2 = GND, pin 5 is a resistor to GND, pin 6 looks like an output with some output capacitance, etc.)
  • \$\begingroup\$ Many thanks! That's the one! \$\endgroup\$
    – Ma Sa
    Commented Sep 27, 2023 at 16:59
