Look at this beautiful circuit simulation, it is in the digital design class document that I received from my teacher.
I want to draw many circuits like that.
What software can I use to draw circuit diagrams like this?
    \$\begingroup\$ A circuit simulation and a circuit diagram are two different things. \$\endgroup\$
    – MiNiMe
    Commented Oct 1, 2023 at 4:03
  • 8
    \$\begingroup\$ Be aware that those are not schematics - but wiring diagrams. Schematics are used to design, analyse, understand and communicate circuits. Wiring diagrams are used for just what the name sounds like, transferring an existing circuit onto a breadboard without wiring mistakes. When the circuit is no more than a LED and a resistor, it's difficult to see the need for the difference. Once you have 20+ components, a wiring diagram gets to be unusable for design, analysis, communication, understanding. This board has a schematic editor built in, try drawing a schematic version of your wiring diagrams \$\endgroup\$
    – Neil_UK
    Commented Oct 1, 2023 at 4:07
  • 4
    \$\begingroup\$ ask your teacher \$\endgroup\$
    – jsotola
    Commented Oct 1, 2023 at 4:25
  • 7
    \$\begingroup\$ Looks like Orcad, and not used very well. \$\endgroup\$ Commented Oct 1, 2023 at 5:08
    \$\begingroup\$ Kudos for desiring craftsmanship. Please apply your artistic intentions to industry-standard schematic diagrams rather than pictorial-type wiring diagrams. Treat schematics as a language - some like Kicad are acceptable. Even with these, you can render a schematic in a cluttered manner, difficult to follow. I've seen auto electrical system schematics that are done in the cluttered manner you intend that would drive an engineer crazy. \$\endgroup\$
    – glen_geek
    Commented Oct 1, 2023 at 12:48
4 Answers 4
14
There are any number of programs out there to draw schematics as you show. Many are payware, some are free. From the looks of the horrible resistor, I would venture to guess that this was done in Orcad Capture.
Please don't emulate these diagrams as there things in there which make the schematic harder to read and artistically unbalanced. Some of the icky things are the upside down ground symbol, ground symbol pointing left, non orthogonal wire, 3-2 humped resistor symbol that is stretched out (this was the awful symbol used in Orcad SDT library back in the 1980s and does not fully conform to the symbol used in the IEEE 315 or ANSI Y32.2 standards). Quad gates are generally drawn as separate gates (four individual gates which is a homogeneous part), not all bundled in to a single package since this would create a wiring mess in many circuits.
Please see this post for hints on drawing a nice schematic.
Just a note that when you're writing a question or answer here, you can click the button that looks like this: enter image description here to draw schematics. I'm certainly not going to claim it's the greatest program possible for the task, but it can produce results that look at least as nice as those you've shown in the question.
For what it's worth, it can do actual circuit simulation as well.
When/if you want to use it outside of an question/answer here, you can go to https://www.circuitlab.com/.
  • \$\begingroup\$ Afraid I can't see how this answers the question ""What software to draw circuit diagrams like this?" as the schematic tool here is nothing like this. Downvoting for that reason. This could have been a comment, with a link to an example schematic in an existing question or answer. \$\endgroup\$
    – TonyM
    Commented Oct 1, 2023 at 7:35
    \$\begingroup\$ @TonyM: In what way do you find it "nothing like this"? There's (perhaps) a rather trivial difference in a provide symbol (showing a gate as a gate, rather than as part of a package), but that's purely a symbol, not anything intrinsic to the software. So, you're obviously free to downvote, but it mostly reflects poorly on you. \$\endgroup\$ Commented Oct 1, 2023 at 8:02
  • \$\begingroup\$ @JerryCoffin I think there are two interpretations. Either, the OP asks in general what kind of different programs there are to draw circuit diagrams, or, which specific program was uses to draw that specific diagram so OP can use the same program. So whether this answers the OPs question depends on what was the intentiom, is the answer simply either "Orcad" or whatever program you want to suggest. But, in the latter case, asking for suggestions what programs to use will be off-topic. So please understand the point of TonyM, you two understand the question differently. \$\endgroup\$
    – Justme
    Commented Oct 1, 2023 at 8:31
  • \$\begingroup\$ Actually, OP's question clearly emphasises they want schematics of the shown standard, to draw a lot so must be productive ("this beautiful circuit simulation", "I want to draw many circuits like that", "What software can I use to draw circuit diagrams like this?). Answers I'd expect would be: KiCAD, OrCAD, things of that standard. This answer recommends only what's, compared to those, little more than a sketch tool with a very very low productivity rate (I know, I've used it a lot here). So downvote, and with an (unrequired by site) explanation. Answers must address the question. \$\endgroup\$
    – TonyM
    Commented Oct 1, 2023 at 9:58
    \$\begingroup\$ I'm not looking for an argument at all, nor have I said anything that suggests anything of the sort. I'm merely pointing out that given his starting point, a tool that's free, and very quick and easy to learn may be far more than adequate. We'd need a lot more detail from the OP to justify a claim that one specific CAD tool is a better choice than another for his (almost completely unknown) purposes. \$\endgroup\$ Commented Oct 1, 2023 at 16:00
I take it you're a student. I'm therefore assuming that you probably are operating on limited funds and are not going to pay for commercial software.
KiCAD is free, and it works well for a lot of circuit design tasks. You can generate a conceptual schematic like you have pictured, and then export the list of parts and connections into the PCB design tool. Then you can lay out the physical design of the circuit board and prepare it for fabrication.
I am not an electrical engineer by education or trade, for me it's just a hobby, and I have had a great experience with KiCAD. Some people complain about it, but it is quite capable and you can't beat the price. enter image description here
Try NI Multisim
We used to use it in many courses at university
