It is said that lithium-ion batteries should not be kept constantly at max charge and also not stored for a long time empty. Let us say that we connect it to a charger that keeps it charged to about 80% all the time and at optimal temperature, and that we never discharge it (cycle it). What will make the battery degrade in this condition? Will the battery in this case last for decades?
As I understand, the shelf life is given as the time it takes to discharge and then go bad because of being in a discharged state, but in this case we never let it discharge.
  • \$\begingroup\$ I see two problems with even assessing this: 1) without cycling, how do you know what is 80%? 2) How do you define&determine End of Life? (I'd suggest differential resistance three halves of initial.) \$\endgroup\$
    – greybeard
    Commented Dec 10, 2023 at 17:29
  • \$\begingroup\$ Anecdotally: This comment is being typed on a laptop with nine year-old battery. It has been kept at 80% charge for almost that entire time. The original capacity was ~49 W-h, it has degraded to ~37 W-h over that time. It still serves its purpose, though it's lost ~30% capacity. Not bad, in my opinion. (I wonder about batteries in implanted medical devices, though... most are not rechargeable, but inductive charging is possible. How long con one avoid being reopened to change the battery?) \$\endgroup\$ Commented Dec 11, 2023 at 5:45
Mostly, the degradation of the electrolyte in each cell in the battery. The voltage across the electrodes causes a electrolysis that disassociates the organic salt. (Note: I am not a chemist, so my terminology is probably off.) The higher the cell voltage, and the higher the temperature, the faster the effect.
Also, over time, the SEI layer on the active material thickens, which consumes lithium. That results in less active material and higher resistance between the electrolyte and the active material. The SEI (solid electrolyte interphase) layer is a good thing because it keeps the electrolyte from attacking the active material. But if the SEI layer is too thick, ions can't cross it.
It depends on what you mean by "Last". Yes, each cell in the battery will still be a working Li-ion cell after decades. Just not a good one: the resistance will have increased and the capacity will have decreased.
