I am debugging a mid-1970s piece of printer equipment and have traced a failure to what looks like a bad transistor. But I can't find a data sheet for it (or a useful substitution). It's a metal can labeled S-1122 (with the old National Semiconductor logo on it). In the documentation for the printer device it's called an "SS1122 PNP transistor". This part seems to have been used in multiple Southwest Technical Products kit devices of the era, but I cannot find it in any of the National databooks I can locate online and googling around doesn't turn up much else of that vintage.
This old thread on DIYAudio talks briefly about it and suggests a substitution ("2n5415, 2n5416") but I'm not sure on what basis.
The 1122 part is being used in this circuit (excerpt, click for full schematic) labeled Q1:
The "motor control" line is a TTL signal that goes low to turn on the AC motor via Q1 and the triac. (The voltage divider at the base of Q1 turns a "low" TTL signal into about 2V where there is 8V at the emitter.)
Can anyone help me find a data sheet for this part, or I suppose failing that, help me identify a useful substitution for this application? Thanks!
