I am doing Single master multiple slave implementation.
Master - PIC18F4550
Slave - PIC18F4520
A potentiometer is connected to the Slave. Slave will convert the Potentiometer value to digital and communicate with the master using SPI protocol.
I am getting 8bit data (ADRESH -- Left justified)correctly from slave. But I have to get 10bit data (ADRESH - 8bit, ADRESL - 2bit).
How can I get 10bit data?
Master code
OpenSPI(SPI_FOSC_64, MODE_01, SMPMID); //SPI configuration
SSPCON1bits.WCOL = 0; //Clearing SSPBUF
LATDbits.LATD0 = 0; //Slave select
WriteSPI(0xFF); //writing 0xFF to slave
for(mdelay = 0; mdelay < 10; mdelay++);
var1 = SSPBUF;
LATDbits.LATD0 = 1;
highbyte = var1;
highbyte = highbyte << 8; //deselecting SS
for(mdelay = 0; mdelay < 100; mdelay++);
LATDbits.LATD0 = 0; //2nd time slave selct
WriteSPI(0xAA);
var2 = SSPBUF;
LATDbits.LATD0 = 1;
lowbyte = var2;
highbyte = highbyte | lowbyte;
result = highbyte;
Slave
int Count;
unsigned char ch1,ch2,data;
ADCON0 = 0x01; // AD Control Register 1: Enable (turn on ADC)
ADCON2 = 0x3C; // AD Control Register 2: 20 TAD (accuracy), FOSC 4 (freq/4)
ADCON2bits.ADFM = 0; // ADC result left justified (D10 - D2 --> ADRESH, D1 - D0 --> ADRESL)
TRISCbits.TRISC3 = 1; //SPI pins(PIC18F4520)
TRISCbits.TRISC4 = 1;
TRISCbits.TRISC5 = 0;
TRISAbits.TRISA5 = 1;
TRISDbits.TRISD0 = 0; //Configuring PORTD as output
TRISDbits.TRISD1 = 0;
TRISDbits.TRISD2 = 0;
TRISDbits.TRISD3 = 0;
TRISDbits.TRISD4 = 0;
TRISDbits.TRISD5 = 0;
TRISDbits.TRISD6 = 0;
TRISDbits.TRISD7 = 0;
SSPSTATbits.SMP = 0; //Configuration of SPI register
SSPSTATbits.CKE = 0;
SSPCON1bits.CKP = 0;
SSPCON1bits.SSPM3 = 0;
SSPCON1bits.SSPM2 = 1;
SSPCON1bits.SSPM1 = 0;
SSPCON1bits.SSPM0 = 0;
SSPCON1bits.SSPEN = 1;
while(1)
ADCON0bits.CHS0 = 1; //Selecting AN0 as analog input
ADCON0bits.CHS1 = 0;
ADCON0bits.CHS2 = 0;
ADCON0bits.CHS3 = 0;
ADCON0bits.GO = 1; //Start analog to digital conversion
while (ADCON0bits.NOT_DONE);
ch1 = ADRESL;
ch2 = ADRESH;
data = SSPBUF; //loading the SSPBUF value to some dummy varible(Previous data in SSPBUF)
//First time slave select
SSPCON1bits.WCOL = 0; //Clearing SSPBUF register
while(PORTAbits.RA5 == 1); //wait for slave select
SSPBUF = ch1; //Loading ADRESH value to SSPBUF
while(SSPSTATbits.BF == 0); //wait untill the buffer is full
for(Count=0;Count<10;Count++); //delay
//Second time slave selct
SSPBUF = ch2; //Loading ADRESL value to SSPBUF
