I'm trying to get my data back from my dead SSD, I found a short on the voltage regulator that become very hot when putting the power but I can't identify the part and get the datasheet.
Here is a a picture from the component itself:
Thanks you for your help!
where exactly? Between the 5V and ground? Did you have a chance to measure the voltage across the 5V output (pins 7-8-9 on the SATA signal connector) and ground (pins 10 or 12 or 4-5-6 on the SATA signal connector)? \$\endgroup\$
