I have a rechargeable coin-cell that needs to be protected from overdischarge. It supplys power to a Real Time Clock and SRAM ICs when my application is not powered(3.5uA). I was thinking of using a supervisor chip that cuts out at 2.0V to protect the battery from discharging below its 2.0V minimum specification. The supervisor can cut power to the RTC and SRAM but then I need to disconnect the supervisor from the coincell. I found supervisors that use ~2uA typical. adding the supervisor would about halve the life of my battery but may be necessary. Once my circuit is powered up and the coin cell recharges, through a parallel diode, the supervisor would again supply power to the IC's
The supervisor I was looking at is NCP304LSQ20T1G.
Any suggestions on how to disconnect the supervisor from the battery or another novel method not using the supervisor to disconnect the battery from the ICs?
