I'm working on a design where I have a need to generate about 10A at 5V across a long bar-shaped board. This is generated from an incoming 12V DC rail. For a number of reasons (physical constraints, thermals, EMI) it makes more sense in my application to use multiple smaller buck converters rather than one large one, producing separate 5V rails for different physical regions of the board. For the purposes of this question, let's assume four buck converters.
I'm looking at buck converters in the 1.5-10MHz switching frequency range. These almost invariably come with a SYNC pin which allows their switching frequencies to be synchronised by an external clock driver. Some of these converters also support spread-spectrum clocking when they are not being synchronised. These features are helpful for mitigating EMI issues and improving PDN integrity.
It appears to me that there are two potential options here.
Option A is to use an external clock generator IC with spread-spectrum support, and generate four clock outputs from that. Ideally these clocks would be shifted 90 degrees in phase to minimise dI/dt on the upstream 12V rail, but the cheaper clockgen options (e.g. Si5351) often don't support that much timing skew control at lower frequencies; as a result the clock phases might be at something like 0°, 45°, 180°, 225°, but this seems generally fine. The clockgen can then be configured for spread-spectrum, e.g. ±1% center spread at ~30kHz rate. All converters operate at the same frequency at any point in time, since the spread-spectrum is global.
Option B is to not synchronise the converters, and use converters with their own spread-spectrum feature. Since nothing is synchronised and all the converters are shifting their switching frequency over time, there will be constant drift. Any overlap between switching edges will be minimised by the pseudorandom behaviour of the system. The converters can also independently adjust their own switching frequency as needed.
Assuming that the cost is roughly equal, what are the pros and cons here?
