I am using 24LC256 EEPROM which have addresses from 0x0000-0x7fff. But I would like to predefine certain address from EEPROM to specific tasks, like from 0-100 for task-1 and so on.
Does predefining those addresses in the C code work?
Like:
const int add[31] =   {0,4,8,12,16,20,24,28,32,36,40};
Will it work or should we point address as 0x0000 - 0x7fff?
And my other question is, how much delay must be done after writing operation (simple write/Page write) in an EEPROM.
The first is a programming issue and the rest of your code will decide how you want to designate the sections of the device.
For the second, the datasheet gives a maximum of 5ms to program a byte or page, but you can use acknowledge polling to check if the device has completed the operation before that time has elapsed; see section 7.0, "Acknowledge Polling" of the Microchip 24AA256/24LC256/24FC256 datasheet for details.
  • \$\begingroup\$ So the first case would work i trust.By declaring address locations as numbers instead of hexadecimal \$\endgroup\$
    – Rookie91
    Commented Nov 6, 2013 at 5:01
    \$\begingroup\$ Oh, is that what that was about? The compiler doesn't care what radix you use for your numbers. \$\endgroup\$ Commented Nov 6, 2013 at 5:04
  • \$\begingroup\$ What would the time needed to read a byte from eeprom? \$\endgroup\$
    – Rookie91
    Commented Nov 6, 2013 at 6:03
  • \$\begingroup\$ No more time than however long it takes to perform the transaction. The data should be available immediately, it's just a question of how quickly you can get it out of the chip on the bus. \$\endgroup\$ Commented Nov 6, 2013 at 6:05
    \$\begingroup\$ @Rookie91: Reading from EEPROM is a much faster operation than writing, so much so that I2C will be the bottleneck, not the EEPROM. \$\endgroup\$ Commented Nov 6, 2013 at 6:19
